はじめに
In this guide, you will learn how to replace the processor in the Dell Inspiron M5030. To remove, clean off, and replace the thermal paste in order to remove the heat sink, please refer to the Applying Thermal Paste Guide.
必要な工具と部品
Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
Turn the laptop over and open the lid.
Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
Locate the blue end of the ribbon which is connected to the motherboard.
Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
Disconnect the blue tab located just above the touch pad of the laptop.
6 の人々がこのガイドを完成させました。
コメント 1 件
Is this the right part number for a cpu replacement for a dell inspiron m5030: PART # 3PDDV?
