メインコンテンツにスキップ
Dell Inspiron 5758 Heatsink and Fan Replacement
必要な工具と部品
  1. Dell Inspiron 5758 Heatsink and Fan Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 2、 3の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 2、 3の画像 2 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 2、 3の画像 3
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: 手順 3、 3の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: 手順 3、 3の画像 2 Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: 手順 3、 3の画像 3
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 4、 1の画像 1
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 5、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 5、 2の画像 2
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 6、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 6、 2の画像 2
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 7、 3の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 7、 3の画像 2 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 7、 3の画像 3
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 8、 1の画像 1
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 9、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 9、 2の画像 2
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 10、 1の画像 1
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 11、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 11、 2の画像 2
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 12、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 12、 2の画像 2
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 13、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 13、 2の画像 2
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 14、 3の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 14、 3の画像 2 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 14、 3の画像 3
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 15、 1の画像 1
    • Remove the bottom base.
  16. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 16、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 16、 2の画像 2
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 17、 3の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 17、 3の画像 2 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 17、 3の画像 3
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 18、 3の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 18、 3の画像 2 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 18、 3の画像 3
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
  19. Dell Inspiron 5758 Heatsink and Fan Replacement, Heatsink and Fan: 手順 19、 1の画像 1
    • After removing the bottom base, you can access the heatsink and fan, which is attached to the motherboard.
  20. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 20、 3の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 20、 3の画像 2 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 20、 3の画像 3
    • Unplug the cable that connects the heatsink and fan to the motherboard.
  21. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 21、 2の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 21、 2の画像 2
    • Loosen the three 5mm screws that connect the heatsink and fan to the motherboard.
    • The screws stay attached to the heatsink and fan. You cannot pull them out, only loosen them.
  22. Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 22、 3の画像 1 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 22、 3の画像 2 Dell Inspiron 5758 Heatsink and Fan Replacement: 手順 22、 3の画像 3
    • Remove the heatsink and fan from the motherboard. You can now clean or replace it as you see fit.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Blase Martin
メンバー登録日: 09/18/18
401 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S3-G4, Raign Fall 2018 University of North Texas, Team S3-G4, Raign Fall 2018人のメンバー
UNT-RAIGN-F18S3G4
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 603
