メインコンテンツにスキップ
Dell Inspiron 3501 Back Cover Replacement
必要な工具と部品
  1. Dell Inspiron 3501 Back Cover Replacement, Unfasten the back cover: 手順 1、 2の画像 1 Dell Inspiron 3501 Back Cover Replacement, Unfasten the back cover: 手順 1、 2の画像 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use the Phillips screwdriver to remove the seven 6 mm-long screws securing the back cover.
    • Use the Phillips screwdriver to loosen the two captive screws.
  2. Dell Inspiron 3501 Back Cover Replacement, Unclip the front corners: 手順 2、 2の画像 1 Dell Inspiron 3501 Back Cover Replacement, Unclip the front corners: 手順 2、 2の画像 2
    • Insert an opening pick between the bottom-left corner of the back cover and the laptop body.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when each clip releases.
    • Repeat this procedure for the bottom-right corner of the back cover.
  3. Dell Inspiron 3501 Back Cover Replacement, Unclip the sides: 手順 3、 2の画像 1 Dell Inspiron 3501 Back Cover Replacement, Unclip the sides: 手順 3、 2の画像 2
    • At the sides of the laptop, insert your opening pick between the cover and body.
    • Pry upward to release the remainder of the clips.
  4. Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 手順 4、 3の画像 1 Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 手順 4、 3の画像 2 Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 手順 4、 3の画像 3
    • Grab the cover by the edge closest to you.
    • Lift the cover up. Swing it open so that the rear edge lifts up last.
    • Completely remove the cover from the laptop.
    • If the back cover is stuck to laptop body, use an opening pick to slide around the perimeter of the back cover to release any remaining clips.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
Clay Eickemeyer
メンバー登録日: 09/19/22
82,264 ポイント
455のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
9 メンバー
11,491のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 19
過去 30 日: 69
今までの合計 1,579
