メインコンテンツにスキップ
Dell Inspiron 16-7610 Motherboard Replacement
必要な工具と部品
  1. Dell Inspiron 16-7610 Motherboard Replacement, Back Case: 手順 1、 2の画像 1 Dell Inspiron 16-7610 Motherboard Replacement, Back Case: 手順 1、 2の画像 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove seven 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
  2. Dell Inspiron 16-7610 Motherboard Replacement: 手順 2、 1の画像 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Motherboard Replacement, Battery: 手順 3、 3の画像 1 Dell Inspiron 16-7610 Motherboard Replacement, Battery: 手順 3、 3の画像 2 Dell Inspiron 16-7610 Motherboard Replacement, Battery: 手順 3、 3の画像 3
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to life the battery up and remove it from the laptop.
  4. Dell Inspiron 16-7610 Motherboard Replacement, Wi-Fi Card: 手順 4、 2の画像 1 Dell Inspiron 16-7610 Motherboard Replacement, Wi-Fi Card: 手順 4、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the screw that secures the Wi-Fi card bracket to the system board.
    • Lift the Wi-Fi card bracket off of the Wi-Fi card.
  5. Dell Inspiron 16-7610 Motherboard Replacement: 手順 5、 2の画像 1 Dell Inspiron 16-7610 Motherboard Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
    • Slide the Wi-Fi card from the slot to remove it from the device.
  6. Dell Inspiron 16-7610 Motherboard Replacement, RAM: 手順 6、 3の画像 1 Dell Inspiron 16-7610 Motherboard Replacement, RAM: 手順 6、 3の画像 2 Dell Inspiron 16-7610 Motherboard Replacement, RAM: 手順 6、 3の画像 3
    • Flip the plastic cover over to reveal the RAM stick. Do not pull the plastic cover off.
    • Pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Pull the RAM stick out of the socket. Repeat for each of the RAM sticks you are replacing.
    • Align your new RAM sticks on to the sockets when installing them to prevent any damage to the pins below.
  7. Dell Inspiron 16-7610 Motherboard Replacement, Motherboard: 手順 7、 1の画像 1
    • Double check that every component is removed from the motherboard.
    • Disconnect all the pin and ribbon cables from the motherboard.
    • Locate and remove all the screws that are holding the motherboard in place.
  8. Dell Inspiron 16-7610 Motherboard Replacement: 手順 8、 3の画像 1 Dell Inspiron 16-7610 Motherboard Replacement: 手順 8、 3の画像 2 Dell Inspiron 16-7610 Motherboard Replacement: 手順 8、 3の画像 3
    • Remove the screws and cables connecting the fans to the motherboard.
    • Lift the fans off of the board to remove.
  9. Dell Inspiron 16-7610 Motherboard Replacement: 手順 9、 2の画像 1 Dell Inspiron 16-7610 Motherboard Replacement: 手順 9、 2の画像 2
    • Use the Phillips #00 screwdriver to loosen the four screws from the heat sink.
    • Use both hands to gently lift the heatsink up.
    • Be mindful of the thermal paste on both the motherboard and the heatsink.
    • We recommend reapplying thermal paste on the heatsink before installing the new motherboard.
  10. Dell Inspiron 16-7610 Motherboard Replacement: 手順 10、 2の画像 1 Dell Inspiron 16-7610 Motherboard Replacement: 手順 10、 2の画像 2
    • Use a spudger to pry up on each side of the press-fit connector, then lift the connector straight up to disconnect it from the motherboard.
  11. Dell Inspiron 16-7610 Motherboard Replacement: 手順 11、 1の画像 1
    • Lift the motherboard out of the device.
終わりに
作成者
5人の作成者と共同で作成されました。
Jerson Gomez
メンバー登録日: 02/02/23
877 ポイント
3のガイドは作成済み
チーム
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023人のメンバー
GCC-PEE-S23S1G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 66
今までの合計 764
