メインコンテンツにスキップ
Dell Inspiron 1525 Heat Sink Replacement
必要な工具と部品
  1. Dell Inspiron 1525 Heat Sink Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Heat Sink Replacement: 手順 2、 2の画像 1 Dell Inspiron 1525 Heat Sink Replacement: 手順 2、 2の画像 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: 手順 3、 2の画像 1 Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: 手順 3、 2の画像 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: 手順 4、 3の画像 1 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: 手順 4、 3の画像 2 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: 手順 4、 3の画像 3
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Miroslav Djuric
159,496 ポイント
144のガイドは作成済み
コメント 1 件
Is there any option to modify the heatsink for better cooling
manashpratim saikia - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 21
今までの合計 7,925
