メインコンテンツにスキップ
Dell Inspiron 15 7579 Speakers Replacement
必要な工具と部品
  1. Dell Inspiron 15 7579 Speakers Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Speakers Replacement: 手順 2、 2の画像 1 Dell Inspiron 15 7579 Speakers Replacement: 手順 2、 2の画像 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Speakers Replacement, Battery: 手順 3、 2の画像 1 Dell Inspiron 15 7579 Speakers Replacement, Battery: 手順 3、 2の画像 2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Speakers Replacement: 手順 4、 1の画像 1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
  5. Dell Inspiron 15 7579 Speakers Replacement, Speakers: 手順 5、 2の画像 1 Dell Inspiron 15 7579 Speakers Replacement, Speakers: 手順 5、 2の画像 2
    この手順で使用する道具:
    • After battery is removed, locate the left and right speakers.
    • On the right speaker assembly, remove the pin connector using the tweezers.
  6. Dell Inspiron 15 7579 Speakers Replacement: 手順 6、 2の画像 1 Dell Inspiron 15 7579 Speakers Replacement: 手順 6、 2の画像 2
    • Use the metal spudger to pry off the right speaker assembly.
  7. Dell Inspiron 15 7579 Speakers Replacement: 手順 7、 1の画像 1
    • Use a metal spudger to pry off left speaker assembly.
  8. Dell Inspiron 15 7579 Speakers Replacement: 手順 8、 2の画像 1 Dell Inspiron 15 7579 Speakers Replacement: 手順 8、 2の画像 2
    • Un-thread the wire by removing them from under the plastic clamps. No tools are required for this step. Repeat for both sides.
  9. Dell Inspiron 15 7579 Speakers Replacement: 手順 9、 2の画像 1 Dell Inspiron 15 7579 Speakers Replacement: 手順 9、 2の画像 2
    • Pull the adhesive cable away from the metal backing and push the right speaker assembly under it.
    • Remove the Velcro holding the speaker wire and remove the speakers from the device.
終わりに
作成者
6人の作成者と共同で作成されました。
Inaki Madrigal
メンバー登録日: 04/23/18
775 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S24G9
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 23
今までの合計 1,293
