はじめに
This guide is to help with the removal and replacement of the Motherboard for the Dell Inspiron 17-7347 laptop. The motherboard is arguably the most important component of the laptop. It controls a majority of the interfaces between different components inside of the laptop.
必要な工具と部品
Flip the device over, so that the back is facing up.
Remove the ten, 7 mm, Phillips #1 screws on the back of your Dell Inspiron 13-7347.
Use the suction cup to lift off the back case.
Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
Lift the hard drive up and out of the device.
Using a Phillips #0 screwdriver, remove the three 3.0 mm heat sink screws.
Remove the Heat Sink.
Using a Phillips #0 screwdriver, remove the 5.0 mm DC jack screw.
Unplug and remove the DC jack.
