はじめに
This will show you how to remove & replace your motherboard. This would be a last step in attempting to repair your computer if you've attempted the other guides.
必要な工具と部品
Use tweezers to pry and remove the center screw cover on the back cover.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
もう少しです!
終わりに
5 の人々がこのガイドを完成させました。
