メインコンテンツにスキップ
Dell Inspiron 11-3162 Motherboard Replacement
必要な工具と部品
  1. Dell Inspiron 11-3162 Motherboard Replacement, Back Cover Removal: 手順 1、 2の画像 1 Dell Inspiron 11-3162 Motherboard Replacement, Back Cover Removal: 手順 1、 2の画像 2
    この手順で使用する道具:
    購入する
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Motherboard Replacement: 手順 2、 2の画像 1 Dell Inspiron 11-3162 Motherboard Replacement: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Motherboard Replacement: 手順 3、 1の画像 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Motherboard Replacement: 手順 4、 3の画像 1 Dell Inspiron 11-3162 Motherboard Replacement: 手順 4、 3の画像 2 Dell Inspiron 11-3162 Motherboard Replacement: 手順 4、 3の画像 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Motherboard Replacement, Battery: 手順 5、 2の画像 1 Dell Inspiron 11-3162 Motherboard Replacement, Battery: 手順 5、 2の画像 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Motherboard Replacement: 手順 6、 3の画像 1 Dell Inspiron 11-3162 Motherboard Replacement: 手順 6、 3の画像 2 Dell Inspiron 11-3162 Motherboard Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 Motherboard Replacement, Wireless WLAN Card: 手順 7、 2の画像 1 Dell Inspiron 11-3162 Motherboard Replacement, Wireless WLAN Card: 手順 7、 2の画像 2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 Motherboard Replacement: 手順 8、 2の画像 1 Dell Inspiron 11-3162 Motherboard Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 Motherboard Replacement: 手順 9、 1の画像 1
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 Motherboard Replacement, Motherboard: 手順 10、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use the tweezers to unplug the DC Jack.
  11. Dell Inspiron 11-3162 Motherboard Replacement: 手順 11、 1の画像 1
    • Use the tweezers unplug the Speaker Cable.
  12. Dell Inspiron 11-3162 Motherboard Replacement: 手順 12、 1の画像 1
    • Use the tweezers to remove the CMOS Cable.
  13. Dell Inspiron 11-3162 Motherboard Replacement: 手順 13、 1の画像 1
    • Use the tweezers to remove the Touchpad Cable.
  14. Dell Inspiron 11-3162 Motherboard Replacement: 手順 14、 3の画像 1 Dell Inspiron 11-3162 Motherboard Replacement: 手順 14、 3の画像 2 Dell Inspiron 11-3162 Motherboard Replacement: 手順 14、 3の画像 3
    • Use the phillips screwdriver with the PH0 to loosen the 4 screws and remove the orange plate.
  15. Dell Inspiron 11-3162 Motherboard Replacement: 手順 15、 2の画像 1 Dell Inspiron 11-3162 Motherboard Replacement: 手順 15、 2の画像 2
    • Use the phillips screwdriver with the PH00 head to unscrew the one 3mm screw. Then, remove the bracket.
  16. Dell Inspiron 11-3162 Motherboard Replacement: 手順 16、 2の画像 1 Dell Inspiron 11-3162 Motherboard Replacement: 手順 16、 2の画像 2
    • Remove the keyboard cable.
  17. Dell Inspiron 11-3162 Motherboard Replacement: 手順 17、 1の画像 1
    • Remove the motherboard by gently lifting upwards from the edges.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dominic DeLong
メンバー登録日: 09/29/16
775 ポイント
4のガイドは作成済み
チーム
Eastern Washington University, Team 1-2, Crane Fall 2016 Eastern Washington University, Team 1-2, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 21
今までの合計 2,249
