メインコンテンツにスキップ
Dell Inspiron 11-3162 LCD Screen Replacement
必要な工具と部品
  1. Dell Inspiron 11-3162 LCD Screen Replacement, Back Cover Removal: 手順 1、 2の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement, Back Cover Removal: 手順 1、 2の画像 2
    この手順で使用する道具:
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 2、 2の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 3、 1の画像 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 4、 3の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 4、 3の画像 2 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 4、 3の画像 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 LCD Screen Replacement, Battery: 手順 5、 2の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement, Battery: 手順 5、 2の画像 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 6、 3の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 6、 3の画像 2 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 LCD Screen Replacement, Wireless WLAN Card: 手順 7、 2の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement, Wireless WLAN Card: 手順 7、 2の画像 2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 8、 2の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 9、 1の画像 1
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 LCD Screen Replacement, LCD Screen: 手順 10、 2の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement, LCD Screen: 手順 10、 2の画像 2
    • Remove the two screws that hold down the LCD hinges.
  11. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 11、 1の画像 1
    • Pull the hinges back and remove the screen.
  12. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 12、 2の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 12、 2の画像 2
    • Remove the hinge covers with your spudger tool.
  13. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 13、 2の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 13、 2の画像 2
    • Carefully remove the LCD Bezel with your regular black nylon spudger tool by bringing it all the way around the outer edges of your screen.
  14. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 14、 3の画像 1 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 14、 3の画像 2 Dell Inspiron 11-3162 LCD Screen Replacement: 手順 14、 3の画像 3
    • Remove the four screws with a PH00 sized bit.
    • Flip the screen over.
  15. Dell Inspiron 11-3162 LCD Screen Replacement: 手順 15、 1の画像 1
    • Loosen the tape, and remove the LCD Cable.
    • Remove the screen.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jared Johnson
メンバー登録日: 09/29/16
589 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 1-2, Crane Fall 2016 Eastern Washington University, Team 1-2, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G2
3 メンバー
6のガイドは作成済み
2件のガイドコメント
Between steps 9 and 10, the motherboard is removed and no description photos are provided for this. I undid the cable on the right hinge and then removed the hinges and screen with the motherboard in place, but the pictures definitely show it removed. Otherwise a very easy to follow process.
Philip Blakemore - 返信
I agree with Philip’s comment re: the missing step between 9 and 10. I successfully followed these very clear instructions to repair my daughter’s Chromebook. Thank you!
Katrina Dalrymple - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 1,833
