メインコンテンツにスキップ
Dell G15-5511 Gaming SSD Replacement
必要な工具と部品
  1. Dell G15-5511 Gaming SSD Replacement, Unfasten the back cover: 手順 1、 2の画像 1 Dell G15-5511 Gaming SSD Replacement, Unfasten the back cover: 手順 1、 2の画像 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws in securing the cover.
    • Use a Phillips #1 screwdriver to loosen the four captive screws.
  2. Dell G15-5511 Gaming SSD Replacement, Unclip the front corners: 手順 2、 2の画像 1 Dell G15-5511 Gaming SSD Replacement, Unclip the front corners: 手順 2、 2の画像 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. Dell G15-5511 Gaming SSD Replacement: 手順 3、 2の画像 1 Dell G15-5511 Gaming SSD Replacement: 手順 3、 2の画像 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5511 Gaming SSD Replacement, Remove the back cover: 手順 4、 3の画像 1 Dell G15-5511 Gaming SSD Replacement, Remove the back cover: 手順 4、 3の画像 2 Dell G15-5511 Gaming SSD Replacement, Remove the back cover: 手順 4、 3の画像 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5511 Gaming SSD Replacement, Disconnect the battery: 手順 5、 3の画像 1 Dell G15-5511 Gaming SSD Replacement, Disconnect the battery: 手順 5、 3の画像 2 Dell G15-5511 Gaming SSD Replacement, Disconnect the battery: 手順 5、 3の画像 3
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5511 Gaming SSD Replacement, Unfasten the SSD Cover: 手順 6、 2の画像 1 Dell G15-5511 Gaming SSD Replacement, Unfasten the SSD Cover: 手順 6、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the two 4.2 mm-long screws securing the copper SSD cover.
  7. Dell G15-5511 Gaming SSD Replacement, Remove the SSD cover: 手順 7、 1の画像 1
    • Pull the SSD cover off by hand or with a pair of blunt nose tweezers.
    • When reassembling with an 80 mm-long full size SSD, do not install this cover.
  8. Dell G15-5511 Gaming SSD Replacement, Remove the SSD: 手順 8、 3の画像 1 Dell G15-5511 Gaming SSD Replacement, Remove the SSD: 手順 8、 3の画像 2 Dell G15-5511 Gaming SSD Replacement, Remove the SSD: 手順 8、 3の画像 3
    • Grip the original SSD by the corners near the screw indent.
    • Pull it straight out of its socket and remove it.
    • Gently wiggle the SSD side to side if it feels stuck.
  9. Dell G15-5511 Gaming SSD Replacement, Remove the SSD standoff: 手順 9、 3の画像 1 Dell G15-5511 Gaming SSD Replacement, Remove the SSD standoff: 手順 9、 3の画像 2 Dell G15-5511 Gaming SSD Replacement, Remove the SSD standoff: 手順 9、 3の画像 3
    • Follow the next four steps to reposition the standoff bracket.
    • Use the flat end of a spudger to push the metal standoff bracket towards the center of the laptop and out of its slot.
    • Use a pair of blunt nose tweezers or your fingers to remove the bracket.
  10. Dell G15-5511 Gaming SSD Replacement, Reinstall the SSD standoff: 手順 10、 3の画像 1 Dell G15-5511 Gaming SSD Replacement, Reinstall the SSD standoff: 手順 10、 3の画像 2 Dell G15-5511 Gaming SSD Replacement, Reinstall the SSD standoff: 手順 10、 3の画像 3
    • Slide the bracket's standoff edge into the adjacent slot.
    • Use the flat end of a spudger to press the the bracket into the slot. The wings of the standoff will clip underneath the tabs of the slot.
  11. Dell G15-5511 Gaming SSD Replacement, SSD installation: 手順 11、 3の画像 1 Dell G15-5511 Gaming SSD Replacement, SSD installation: 手順 11、 3の画像 2 Dell G15-5511 Gaming SSD Replacement, SSD installation: 手順 11、 3の画像 3
    • Grip your 80 mm-long (M.2 2280) SSD by the corners near the screw indent.
    • Slide the SSD into the socket.
  12. Dell G15-5511 Gaming SSD Replacement, Fasten the SSD: 手順 12、 2の画像 1 Dell G15-5511 Gaming SSD Replacement, Fasten the SSD: 手順 12、 2の画像 2
    • Use your Phillips #0 screwdriver to fasten the 4.2 mm-long screw to the SSD standoff.
終わりに
To reassemble your Dell G15, follow these instructions in reverse order.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Clay Eickemeyer
メンバー登録日: 09/19/22
21,776 ポイント
175のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
137 メンバー
17,055のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 70
今までの合計 305
