この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace the motherboard if there is no simpler solution.
必要な工具と部品
Locate the two holes on the bottom of the monitor.
Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
Continue prying along the entire edge of the monitor.
With the monitor facing down, remove the two 5.81 mm Phillips #2 screws on the right side of the metal casing.
With the monitor still facing down, remove the two 5.81 mm Phillips #2 screws on the left side of the casing.
There is a wire connecting the motherboard to the inverter board. Squeeze both sides of the connector and pull to remove it from the socket.
There is another wire connecting the button board to the inverter board. Remove the second white wire connector.
A third wire connects the inverter board to the screen circuit board. Remove the black wire connector.
The inverter board can now be fully removed.
With the monitor facing down, remove the 5.84 mm Phillips #2 screw from the metal sheet.
