はじめに
If your screen is cracked or not functioning correctly, follow this guide.
必要な工具と部品
First, disassemble the device, taking off the top and bottom panels. See the disassembly guide for further directions.
To replace, purchase a new screen and locate the small silver bar located on the motherboard.
Insert the end of the new screen into the opening of the silver bar, securing it in there to hold your new screen.
After the device is assembled, power the device on. The issue should be repaired.
If the device screen is still defective, an issue with the motherboard or a greater malfunction could be the cause.
