メインコンテンツにスキップ
Dell DJ Screen Replacement
必要な工具と部品
  1. Dell DJ Screen Replacement, Screen: 手順 1、 2の画像 1 Dell DJ Screen Replacement, Screen: 手順 1、 2の画像 2
    • First, disassemble the device, taking off the top and bottom panels. See the disassembly guide for further directions.
  2. Dell DJ Screen Replacement: 手順 2、 3の画像 1 Dell DJ Screen Replacement: 手順 2、 3の画像 2 Dell DJ Screen Replacement: 手順 2、 3の画像 3
    • Slide the internal components out of the case.
    • Clean all areas of the device, making sure to clear all crevices of dirt and grime. Appropriate materials include: a water dampened cotton cloth, microfiber cloth, cotton swabs, and disposable wipes made for electronic devices.
    • If the device has a lot of dirt on the internal components, this may be the cause of the screen malfunction. Reassemble device at this point to see if it has fixed the problem.
  3. Dell DJ Screen Replacement: 手順 3、 2の画像 1 Dell DJ Screen Replacement: 手順 3、 2の画像 2
    • Disconnect side clips of screen to detach the base of it from the main circuit board, using the metal spudger.
  4. Dell DJ Screen Replacement: 手順 4、 3の画像 1 Dell DJ Screen Replacement: 手順 4、 3の画像 2 Dell DJ Screen Replacement: 手順 4、 3の画像 3
    • Carefully pull the screen up so that it is only attached at the top side.
    • Pull gently to fully detach screen from device.
  5. Dell DJ Screen Replacement: 手順 5、 2の画像 1 Dell DJ Screen Replacement: 手順 5、 2の画像 2
    • To replace, purchase a new screen and locate the small silver bar located on the motherboard.
    • Insert the end of the new screen into the opening of the silver bar, securing it in there to hold your new screen.
    • After the device is assembled, power the device on. The issue should be repaired.
    • If the device screen is still defective, an issue with the motherboard or a greater malfunction could be the cause.
終わりに
作成者
3人の作成者と共同で作成されました。
Brittany Abate
メンバー登録日: 01/03/16
407 ポイント
4のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2016人のメンバー
USFSM-STEWART-S16S1G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 268
