メインコンテンツにスキップ
Dell Chromebook 5190 Motherboard Replacement
必要な工具と部品
  1. Dell Chromebook 5190 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 Motherboard Replacement: 手順 2、 3の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 2、 3の画像 2 Dell Chromebook 5190 Motherboard Replacement: 手順 2、 3の画像 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 Motherboard Replacement: 手順 3、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 3、 2の画像 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 Motherboard Replacement: 手順 4、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 Motherboard Replacement: 手順 5、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 Motherboard Replacement: 手順 6、 3の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 6、 3の画像 2 Dell Chromebook 5190 Motherboard Replacement: 手順 6、 3の画像 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • To disconnect the first purple I/O cable, first lift the purple tab upwards.
    • Next, pull the purple tab away from the motherboard.
  8. Dell Chromebook 5190 Motherboard Replacement: 手順 8、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 8、 2の画像 2
    • To disconnect the second purple I/O cable, first lift the purple tab upwards.
  9. Dell Chromebook 5190 Motherboard Replacement: 手順 9、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 9、 2の画像 2
    • To disconnect the touchpad cable, first lift the purple tab upwards.
  10. Dell Chromebook 5190 Motherboard Replacement: 手順 10、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 10、 2の画像 2
    • Push downwards on the black tabs located on both side of the motherboard connector.
    • Disconnect the keyboard cable.
  11. Dell Chromebook 5190 Motherboard Replacement: 手順 11、 1の画像 1
    • Disconnect the speaker cable by pulling it from the motherboard connector.
  12. Dell Chromebook 5190 Motherboard Replacement: 手順 12、 3の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 12、 3の画像 2 Dell Chromebook 5190 Motherboard Replacement: 手順 12、 3の画像 3
    • Screw the single (M2x4) screw on the eDP bracket.
    • Unhook the eDP bracket.
    • Lift the eDP bracket off.
  13. Dell Chromebook 5190 Motherboard Replacement: 手順 13、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 13、 2の画像 2
    • Remove clear adhesive tape off the motherboard connector.
    • Lift the black tab located on the display connector.
  14. Dell Chromebook 5190 Motherboard Replacement: 手順 14、 2の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 14、 2の画像 2
    • Disconnect the display cable from the motherboard connector.
    • Remove the adhesive tape from the motherboard.
  15. Dell Chromebook 5190 Motherboard Replacement: 手順 15、 3の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 15、 3の画像 2 Dell Chromebook 5190 Motherboard Replacement: 手順 15、 3の画像 3
    • Unscrew the single (M2x4) screw from the motherboard bracket.
    • Unhook the motherboard bracket.
    • Lift the motherboard bracket.
  16. Dell Chromebook 5190 Motherboard Replacement: 手順 16、 3の画像 1 Dell Chromebook 5190 Motherboard Replacement: 手順 16、 3の画像 2 Dell Chromebook 5190 Motherboard Replacement: 手順 16、 3の画像 3
    • Unscrew 3 (M2x3) screws on the motherboard.
    • Unhook the motherboard by placing it at an angle.
    • Lift the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Denise Cano
メンバー登録日: 02/10/22
617 ポイント
4のガイドは作成済み
チーム
Gateway, Team 1-3, Pee Spring 2022 Gateway, Team 1-3, Pee Spring 2022人のメンバー
GCC-PEE-S22S1G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 499
