メインコンテンツにスキップ
Dell Chromebook 3100 Battery Replacement
必要な工具と部品
  1. Dell Chromebook 3100 Battery Replacement, Remove Bottom Cover: 手順 1、 2の画像 1 Dell Chromebook 3100 Battery Replacement, Remove Bottom Cover: 手順 1、 2の画像 2
    • Remove the 9 screws from the back cover with the Phillips #0 screwdriver. NOTE* You do not need to remove the screws completely as you just need to loosen them enough to remove the cover.
    • Once all 9 screws have been loosened, you can start to pry apart the back cover with your metal or plastic blade. I like to start from the top right hinge area. (See pic)
  2. Dell Chromebook 3100 Battery Replacement, #1 - Remove Battery Screws: 手順 2、 1の画像 1
    • Remove the 3 battery screws with a Phillips #0 screwdriver.
    • Temporarily disconnect the sticker on the bottom left corner of the battery. You will need to reconnect this sticker when installing the new battery.
    • Lift the battery out of the palm rest. You may feel some resistance while trying to remove the battery. There is a piece of double-sided tape underneath the battery in the top left corner. (See video)
    • Disconnect the motherboard battery cable from the top of the battery.
終わりに
作成者
4人の作成者と共同で作成されました。
Jon
メンバー登録日: 08/18/13
3,921 ポイント
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 60
今までの合計 1,310
