メインコンテンツにスキップ
DeWalt DWE305 Motor Assembly Replacement
必要な工具と部品
  1. DeWalt DWE305 Motor Assembly Replacement, Motor Assembly: 手順 1、 1の画像 1
    • Remove the large screw from the locking area of the device using a Phillips #2 screwdriver.
  2. DeWalt DWE305 Motor Assembly Replacement: 手順 2、 3の画像 1 DeWalt DWE305 Motor Assembly Replacement: 手順 2、 3の画像 2 DeWalt DWE305 Motor Assembly Replacement: 手順 2、 3の画像 3
    • Remove all seven 3/4" button head Torx security screws on the left side of the handle with a Torx T20H screwdriver.
    • Remove the left side of the handle shown in the second picture.
    • Remove the single 3/4" button head Torx security screw from inside the handle using the Torx T15H screwdriver, and remove the trigger assembly from the handle and move aside.
  3. DeWalt DWE305 Motor Assembly Replacement: 手順 3、 1の画像 1
    • Use a Torx T20H scrrwdriver to remove the four 3/4" button head Torx security screws from inside the saw blade housing.
    • Be cautious of the sharp points on the housing.
  4. DeWalt DWE305 Motor Assembly Replacement: 手順 4、 2の画像 1 DeWalt DWE305 Motor Assembly Replacement: 手順 4、 2の画像 2
    • Pull the black plastic cover (the shoe) from the device.
    • Slide the black rubber component (the boot) off to expose the reciprocating shaft and metal plate.
    • There will be white lithium grease used for lubrication on the internal surface of the cover.
  5. DeWalt DWE305 Motor Assembly Replacement: 手順 5、 1の画像 1
    • Remove the rubber gasket from over the four Torx security screws at the base of the gear assembly on the lower part of the device.
    • Be sure to make note of the proper facing and direction of this rubber gasket, and do not forget this piece during reassembly.
  6. DeWalt DWE305 Motor Assembly Replacement: 手順 6、 2の画像 1 DeWalt DWE305 Motor Assembly Replacement: 手順 6、 2の画像 2
    • Remove the four 3/4" button head Torx security screws from the front with the Torx T20H screwdriver.
    • Turn the device over and remove the two 3/4" screws from the handle area with the Torx T20H screwdriver.
  7. DeWalt DWE305 Motor Assembly Replacement: 手順 7、 1の画像 1
    • Pull out the motor assembly and inspect it for damage or dust.
    • The motor assembly is magnetic, so it may take a bit of force to remove it.
  8. DeWalt DWE305 Motor Assembly Replacement: 手順 8、 1の画像 1
    • If there is damage, then replace or repair the device.
    • If no damage is observed, then other components should be examined.
終わりに
作成者
7人の作成者と共同で作成されました。
Leanna Pollicar
メンバー登録日: 09/16/19
351 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 439
