メインコンテンツにスキップ
DOPO 10.1 Tablet Speaker Replacement
必要な工具と部品
  1. DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: 手順 1、 3の画像 1 DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: 手順 1、 3の画像 2 DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: 手順 1、 3の画像 3
    • • Insert tool into crease between covers. First, insert one of the plastic tools between the front and back cover as shown. Next, twist the plastic tool until separation has occurred between the front and back of the tablet. Repeat this step until the user is able to fully separate the front and back covers.
  2. DOPO 10.1 Tablet Speaker Replacement, Locate the Speakers: 手順 2、 2の画像 1 DOPO 10.1 Tablet Speaker Replacement, Locate the Speakers: 手順 2、 2の画像 2
    • The speakers should be attached to the white cover of the tablet as shown. Follow the wires back to the mother board making sure to remove all tape attaching wires to cover along the way. This will free up the wires for easy maneuverability.
  3. DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: 手順 3、 3の画像 1 DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: 手順 3、 3の画像 2 DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: 手順 3、 3の画像 3
    • We will need to separate the battery from the panel slightly. This will allow for easier maneuverability to remove speakers. Do not separate the battery completely.
  4. DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: 手順 4、 3の画像 1 DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: 手順 4、 3の画像 2 DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: 手順 4、 3の画像 3
    • De-solder the red and black wires from the tablets motherboard. This will officially disconnect, and separate the defective speakers from the motherboard.
  5. DOPO 10.1 Tablet Speaker Replacement, Removing Speakers: 手順 5、 1の画像 1
    • Remove defective speakers from their location in tablet.
終わりに
作成者
3人の作成者と共同で作成されました。
Kaitlyn Hayes
メンバー登録日: 01/21/15
414 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 5-2, Brown Winter 2015 USF Tampa, Team 5-2, Brown Winter 2015人のメンバー
USFT-BROWN-W15S5G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 8
今までの合計 922
