メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DJI Phantom 2 Vision Outer Shell Replacement
必要な工具と部品
  1. DJI Phantom 2 Vision Outer Shell Replacement, Battery: 手順 1、 1の画像 1
    • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
    • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
  2. DJI Phantom 2 Vision Outer Shell Replacement: 手順 2、 2の画像 1 DJI Phantom 2 Vision Outer Shell Replacement: 手順 2、 2の画像 2
    • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
  3. DJI Phantom 2 Vision Outer Shell Replacement: 手順 3、 1の画像 1
    • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
    • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
  4. DJI Phantom 2 Vision Outer Shell Replacement, Outer Shell: 手順 4、 2の画像 1 DJI Phantom 2 Vision Outer Shell Replacement, Outer Shell: 手順 4、 2の画像 2
    • Remove the propellers before taking off the top shell. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
    • Flip the device so the motors are facing down.
    • Remove four 6 mm screws next to the landing gear on each arm using a 2 mm Hex key.
  5. DJI Phantom 2 Vision Outer Shell Replacement: 手順 5、 1の画像 1
    • Remove eight 9 mm screws using a 2 mm Hex key.
    • Remove four 9 mm screws using a Phillips #00 screwdriver.
  6. DJI Phantom 2 Vision Outer Shell Replacement: 手順 6、 2の画像 1 DJI Phantom 2 Vision Outer Shell Replacement: 手順 6、 2の画像 2
    • Slowly lift the shell off the device.
    • Disconnect the GPS wire from the motherboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Dylan Ponder
メンバー登録日: 09/15/24
386 ポイント
4のガイドは作成済み
チーム
Austin Community College, Team 7-1, Watkins Fall 2024 Austin Community College, Team 7-1, Watkins Fall 2024人のメンバー
AUSTINCC-WATKINS-F24S7G1
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 141
