メインコンテンツにスキップ
DJI Phantom 2 Vision Landing Gear Replacement
必要な工具と部品
  1. DJI Phantom 2 Vision Landing Gear Replacement, Battery: 手順 1、 1の画像 1
    • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
    • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
  2. DJI Phantom 2 Vision Landing Gear Replacement: 手順 2、 2の画像 1 DJI Phantom 2 Vision Landing Gear Replacement: 手順 2、 2の画像 2
    • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
  3. DJI Phantom 2 Vision Landing Gear Replacement: 手順 3、 1の画像 1
    • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
    • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
  4. DJI Phantom 2 Vision Landing Gear Replacement, Gimbal Housing: 手順 4、 2の画像 1 DJI Phantom 2 Vision Landing Gear Replacement, Gimbal Housing: 手順 4、 2の画像 2
    • Remove the propellers before you begin. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
    • Flip the drone over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove the four 6 mm screws.
    • To access the screws, slowly pull back on the mount in the opposite direction.
  5. DJI Phantom 2 Vision Landing Gear Replacement: 手順 5、 2の画像 1 DJI Phantom 2 Vision Landing Gear Replacement: 手順 5、 2の画像 2
    • Unplug the wire connecting the camera to the drone.
  6. DJI Phantom 2 Vision Landing Gear Replacement: 手順 6、 2の画像 1 DJI Phantom 2 Vision Landing Gear Replacement: 手順 6、 2の画像 2
    • Slowly lift the gimbal housing from the device.
    • Gently disconnect the camera cable from the cable connected to the motherboard.
    • Push on alternating sides of the connector and pull straight away from the socket.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • Do not pull on the wire cables as this may cause damage.
    • The gimbal housing should now be disconnected from the drone.
  7. DJI Phantom 2 Vision Landing Gear Replacement, Landing Gear: 手順 7、 1の画像 1
    • Locate Landing gears, This should be on the bottom of the drone Holding it up if flipped right side up.
  8. DJI Phantom 2 Vision Landing Gear Replacement: 手順 8、 3の画像 1 DJI Phantom 2 Vision Landing Gear Replacement: 手順 8、 3の画像 2 DJI Phantom 2 Vision Landing Gear Replacement: 手順 8、 3の画像 3
    • Unscrew each of the 8(9mm) screws using a #1 Philips head bit. These should be near the base of the drone, 2 by each leg of the landing gear.
  9. DJI Phantom 2 Vision Landing Gear Replacement: 手順 9、 1の画像 1
    • Remove landing gear off of each side of device.
終わりに
作成者
2人の作成者と共同で作成されました。
Dylan Ponder
メンバー登録日: 09/15/24
386 ポイント
4のガイドは作成済み
チーム
Austin Community College, Team 7-1, Watkins Fall 2024 Austin Community College, Team 7-1, Watkins Fall 2024人のメンバー
AUSTINCC-WATKINS-F24S7G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 24
今までの合計 43
