メインコンテンツにスキップ
DJI Phantom 2 Vision Battery Replacement
必要な工具と部品
  1. DJI Phantom 2 Vision Battery Replacement, Battery: 手順 1、 1の画像 1
    • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
    • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
  2. DJI Phantom 2 Vision Battery Replacement: 手順 2、 2の画像 1 DJI Phantom 2 Vision Battery Replacement: 手順 2、 2の画像 2
    • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
  3. DJI Phantom 2 Vision Battery Replacement: 手順 3、 1の画像 1
    • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
    • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
4人の作成者と共同で作成されました。
Dylan Ponder
メンバー登録日: 09/15/24
386 ポイント
4のガイドは作成済み
チーム
Austin Community College, Team 7-1, Watkins Fall 2024 Austin Community College, Team 7-1, Watkins Fall 2024人のメンバー
AUSTINCC-WATKINS-F24S7G1
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 154
