メインコンテンツにスキップ
DJI Phantom 2 Vision+ ESC Removal
必要な工具と部品
  1. DJI Phantom 2 Vision+ ESC Removal, Remove the battery: 手順 1、 3の画像 1 DJI Phantom 2 Vision+ ESC Removal, Remove the battery: 手順 1、 3の画像 2 DJI Phantom 2 Vision+ ESC Removal, Remove the battery: 手順 1、 3の画像 3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. DJI Phantom 2 Vision+ ESC Removal, Propellers: 手順 2、 1の画像 1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: 手順 3、 3の画像 1 DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: 手順 3、 3の画像 2 DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: 手順 3、 3の画像 3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: 手順 4、 3の画像 1 DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: 手順 4、 3の画像 2 DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: 手順 4、 3の画像 3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
  5. DJI Phantom 2 Vision+ ESC Removal, Case Top Shell: 手順 5、 2の画像 1 DJI Phantom 2 Vision+ ESC Removal, Case Top Shell: 手順 5、 2の画像 2
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  6. DJI Phantom 2 Vision+ ESC Removal: 手順 6、 2の画像 1 DJI Phantom 2 Vision+ ESC Removal: 手順 6、 2の画像 2
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  7. DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: 手順 7、 3の画像 1 DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: 手順 7、 3の画像 2 DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: 手順 7、 3の画像 3
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
  8. DJI Phantom 2 Vision+ ESC Removal, Desolder motor wires: 手順 8、 2の画像 1 DJI Phantom 2 Vision+ ESC Removal, Desolder motor wires: 手順 8、 2の画像 2
    • Desolder all three motor wires.
    • When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
    • The motor spin direction is dependent on the order of the wires, and may not match this image exactly. If you forgot the order, check the arm directly opposite for reference.
  9. DJI Phantom 2 Vision+ ESC Removal: 手順 9、 1の画像 1
    • Remove the four 2mm hex motor bolts.
  10. DJI Phantom 2 Vision+ ESC Removal: 手順 10、 2の画像 1 DJI Phantom 2 Vision+ ESC Removal: 手順 10、 2の画像 2
    • Remove the motor from the motor mount.
  11. DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: 手順 11、 3の画像 1 DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: 手順 11、 3の画像 2 DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: 手順 11、 3の画像 3
    • Cut the zip-tie securing the signal and power cables.
    • Unplug the ESC signal cable molex connector from the ESC.
  12. DJI Phantom 2 Vision+ ESC Removal, Desolder the ESC: 手順 12、 2の画像 1 DJI Phantom 2 Vision+ ESC Removal, Desolder the ESC: 手順 12、 2の画像 2
    • Desolder the ESC ground and voltage wires from the mainboard.
    • Be careful not to melt the plastic case bottom shell with your soldering iron or damage any electronic components.
    • You can remove in-the-way cables by unplugging them and moving them aside. This will protect them from the warning above.
    • Be sure to plug these cables back in before reassembling your Phantom 2.
  13. DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: 手順 13、 3の画像 1 DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: 手順 13、 3の画像 2 DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: 手順 13、 3の画像 3
    • Remove the two ESC securing screws.
    • The clear plastic LED cover will either drop from the underside or need to be loosened with a plastic spudger.
  14. DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: 手順 14、 3の画像 1 DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: 手順 14、 3の画像 2 DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: 手順 14、 3の画像 3
    • With the ESC no longer secured to the airframe, lift it up and remove it.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
David Hoyt
メンバー登録日: 04/09/10
4,053 ポイント
41のガイドは作成済み
チーム
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G89
4 メンバー
61のガイドは作成済み
コメント 1 件
Is it a difference between ESC from different versions (1.0, 2.0 and 3.0) of Phantom 2?
jarbas_sjo - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 6,542
