はじめに
We are defining the DJI Mini 2 drone body as the top and bottom plastic panels of the drone. These panels are the blockaded between the insides of the drone and the outside world.
The drone body stores the inner electronic parts of the drone like the GPS, the Main Board, and the wires the drone uses. Damage to the drone body can cause the drone to be unstable in flight. If the body of the drone is damaged they will need to be replaced.
必要な工具と部品
Face the DJI Mini 2 away from you so that you are looking at the charging ports.
Use your finger to open up the back panel.
6 の人々がこのガイドを完成させました。
