メインコンテンツにスキップ
DJI Mavic Pro Top Case Removal
必要な工具と部品
ビデオの概要
  1. DJI Mavic Pro Top Case Removal, Remove Battery: 手順 1、 3の画像 1 DJI Mavic Pro Top Case Removal, Remove Battery: 手順 1、 3の画像 2 DJI Mavic Pro Top Case Removal, Remove Battery: 手順 1、 3の画像 3
    • To start removing screws, you must first remove the battery, by squeezing the sides of the battery, as shown in the photos, and lighting it up and away from the drone.
  2. DJI Mavic Pro Top Case Removal, Remove screws under the battery: 手順 2、 1の画像 1
    • There are 6 screws on the top of the drone. Four of them are located under the battery, and the other two are right on the back end of the drone. They are all 5.8mm long, and have a 1.5mm hex head, I, however, found that they are easier to remove using a T6H Torx bit.
  3. DJI Mavic Pro Top Case Removal, Remove Screws on the Bottom: 手順 3、 2の画像 1 DJI Mavic Pro Top Case Removal, Remove Screws on the Bottom: 手順 3、 2の画像 2
    • Now, flip over the drone, and orient it with the camera facing you. You should remove the camera/gimbal cover at this point, but its probably a good idea to leave the gimbal brace in place.
    • Remove the four closest screws circled in red. The ones closest to the front are 5.8mm long, with a 2mm diameter, while the ones closer to the rear of the drone are 4.8mm long, with a 1.5mm diameter. Be careful not to confuse these screws when reassembling the drone.
  4. DJI Mavic Pro Top Case Removal, Remove the Plastic Covers That Cover the Front Arm Hinge: 手順 4、 3の画像 1 DJI Mavic Pro Top Case Removal, Remove the Plastic Covers That Cover the Front Arm Hinge: 手順 4、 3の画像 2 DJI Mavic Pro Top Case Removal, Remove the Plastic Covers That Cover the Front Arm Hinge: 手順 4、 3の画像 3
    • There are screws under these covers, which need to be removed, as they hold the top plate in place. to do this, you need to take something sharp, a flat edge hobby knife, for example, and pop the cover up out of place in the front end, and then work your way around to the rear of them, once you get to the back, it should pop right off.
    • You will need to do this on both the left and right side of the drone.
    • My apologies, the wrong area is in focus in these pictures, but I feel that they can still serve their purpose adequately.
  5. DJI Mavic Pro Top Case Removal, Remove the Screws Under the Front Arm Covers: 手順 5、 1の画像 1
    • There are two 1.5mm hex screws, these are 5.8mm long, with a 2mm diameter. These are thicker than the screws holding the covers down, because those screws are only holding the covers down, while the screws under it are holding the top cover down. Take note of this during reassembly.
  6. DJI Mavic Pro Top Case Removal, Pry up Rear Case: 手順 6、 3の画像 1 DJI Mavic Pro Top Case Removal, Pry up Rear Case: 手順 6、 3の画像 2 DJI Mavic Pro Top Case Removal, Pry up Rear Case: 手順 6、 3の画像 3
    • First, turn the drone over, so it is right side up, and facing away from you. Now, use a metal spudger to pry open the rear end of the case. Be careful not to pull too far up, as there is still a cable which is connecting the two pieces.
    • Slide the spudger down the length of each side, undoing all the clips along the way, stop 1-2 cm before the ending of the battery cradle.
  7. DJI Mavic Pro Top Case Removal, Disconnect GPS From Logic Board: 手順 7、 3の画像 1 DJI Mavic Pro Top Case Removal, Disconnect GPS From Logic Board: 手順 7、 3の画像 2 DJI Mavic Pro Top Case Removal, Disconnect GPS From Logic Board: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Gently lift up the rear of the top case .5-1mm, and insert a pair of tweezers, grab the black cloth shielded cable connecting the top and bottom, and gently pull it up and away from the bottom board. The rear should lift freely up from the case 2-3mm.
  8. DJI Mavic Pro Top Case Removal, Remove Front End of Top Cover: 手順 8、 1の画像 1
    • Insert your metal spudger in between the top and bottom case on both the left and right sides of the drone, as shown in the photo. Pry up gently until it is free.
  9. DJI Mavic Pro Top Case Removal, Unhinge Front Edge of Top Cover: 手順 9、 2の画像 1 DJI Mavic Pro Top Case Removal, Unhinge Front Edge of Top Cover: 手順 9、 2の画像 2
    • This part is tricky. There are four clips folding the front edge in place. Half are facing one direction and half are facing he opposite direction. Be gentle and careful when disengaging them. The photos here, show the locations and directions of the clips.
終わりに
28 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew spoelstra
メンバー登録日: 01/14/15
929 ポイント
1ガイドが承認済み
チーム
Digital-Hospital Digital-Hospital人のメンバー
Business
1 メンバー
1のガイドは作成済み
13 件のコメント
I had a crash .a small crash. looking down on the drone it would be the rear view and is the left rear folding arm ,the stop for this arm when unfolded the crash broke the stop for the left rear arm . I have used a glue to reset the stop how ever I think this is only a very temp fix I think I will have to replace the hole under structure case for the drone . sorry my name is David from Saskatchewan . Canada
David Hall - 1 minute ago Edit Delete Reply
David Hall - 返信
Honestly, I would highly recommend you replace any pieces that show any cracks, or structural flaws, as the last thing you want is that glue giving out during a flight and your drone plummeting to the ground. The plastic case pieces and the arms are not very expensive, compared to the cost of a worse crash as a result of one because of cracked glue. Good luck!
Andrew spoelstra -
I guess it’s going to be difficult to insert the GPS cable again.
Juan - 返信
Actually you can reconnect it before you start clipping the case into place, you just have to be careful and gentle with it.
Andrew spoelstra -
I have broken one of the wires of the piug in under the shell that goes to the gps on mavic pro can it be bought seperate
John Hinckle - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 15
過去 30 日: 69
今までの合計 16,329
