はじめに
This repair/ replacement may be needed if the lettering on the knobs have worn off or if the knobs have been snapped off.
ツール
パーツ
パーツは指定されていません。
Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
The aligned parts will allow the cooking surfaces to work properly.
Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
Move the circuit board to the side so it is out of the way.
ある他の人がこのガイドを完成しました。
12 件のコメント
Where do you find the replacement knobs?
im in same boat can't find the dials/knobs- 2 of mine are broken and useless
I have several cuisinart appliances. I won't ever buy another. I need one replacement knob, the best they can do is 20 percent off on a new griddler . I can get that from bed bath and beyond. Thanks cuisinart, finding new brands. Cuisinart is dead to me.
Same here 2 knobs broken in 2 years and no way to find a new one
