メインコンテンツにスキップ
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement
必要な工具と部品
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement, Power Cord: 手順 1、 1の画像 1
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 手順 2、 1の画像 1
    • Remove the black plastic covering from the motor base.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 手順 3、 1の画像 1
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 手順 4、 1の画像 1
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 手順 5、 1の画像 1
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: 手順 6、 1の画像 1
    • Fit the wires back into the motor base and place the new power cord in the slot.
終わりに
By the end of this guide< you will have successfully replaced the power cord to your device.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Reagan Burns
メンバー登録日: 04/02/15
119 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 24-1, Lancaster Spring 2015 Cal Poly, Team 24-1, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G1
2 メンバー
1のガイドは作成済み
4 件のコメント
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - 返信
I need one also. drshtender1@gmail.com
Feivel Garnick -
Where can you buy the replacement cord?
ruby48lp - 返信
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
Riley Carns - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 18
今までの合計 1,637
