メインコンテンツにスキップ
Cuisinart DCC-1200 Heating Element Replacement
必要な工具と部品
  1. Cuisinart DCC-1200  Heating Element Replacement, Heating Element: 手順 1、 3の画像 1 Cuisinart DCC-1200  Heating Element Replacement, Heating Element: 手順 1、 3の画像 2 Cuisinart DCC-1200  Heating Element Replacement, Heating Element: 手順 1、 3の画像 3
    • Flip the coffee maker over so the bottom is facing up.
    • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
  2. Cuisinart DCC-1200  Heating Element Replacement: 手順 2、 3の画像 1 Cuisinart DCC-1200  Heating Element Replacement: 手順 2、 3の画像 2 Cuisinart DCC-1200  Heating Element Replacement: 手順 2、 3の画像 3
    • Squeeze the hose clamps together and begin moving the metal clamp away from the heating element.
    • Gently pull on the loose hose to remove it from the heating element.
  3. Cuisinart DCC-1200  Heating Element Replacement: 手順 3、 2の画像 1 Cuisinart DCC-1200  Heating Element Replacement: 手順 3、 2の画像 2
    • Repeat previous step to disconnect the other attached water hose.
  4. Cuisinart DCC-1200  Heating Element Replacement: 手順 4、 2の画像 1 Cuisinart DCC-1200  Heating Element Replacement: 手順 4、 2の画像 2
    • Use the bit driver with the extension attachment with the PH1 Phillips bit to remove the two 18mm long screws on heating element plate.
  5. Cuisinart DCC-1200  Heating Element Replacement: 手順 5、 2の画像 1 Cuisinart DCC-1200  Heating Element Replacement: 手順 5、 2の画像 2
    • If heating contacts are connected, use a soldering iron to desolder the bond between metal contact points.
    • Solder iron can cause burns if used improperly
  6. Cuisinart DCC-1200  Heating Element Replacement: 手順 6、 3の画像 1 Cuisinart DCC-1200  Heating Element Replacement: 手順 6、 3の画像 2 Cuisinart DCC-1200  Heating Element Replacement: 手順 6、 3の画像 3
    • Remove the heating element clamp and set aside to access the heating element.
    • Gently squeeze and pull up on metal clamp attached to the heating element.
  7. Cuisinart DCC-1200  Heating Element Replacement: 手順 7、 1の画像 1
    • Remove and replace the defective heating element.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Austin Wheaton
メンバー登録日: 02/15/18
861 ポイント
4のガイドは作成済み
チーム
UW Stout, Team S8-G1, Ogden Spring 2018 UW Stout, Team S8-G1, Ogden Spring 2018人のメンバー
UWSTOUT-OGDEN-S18S8G1
4 メンバー
5のガイドは作成済み
19 件のコメント
Where do you find a replacement heating element?
Evan Dunville - 返信
Finding the replacement heater element is the real challenge:)
vvaccaro - 返信
I have a Cusinart DCC-2600 coffee maker that has stopped heating. I suspect the heating element needs replacing. The bottom of the maker looks very similar to the DCC-1200 shown above, but the 4 screws that hold the bottom on my model do not have any torx heads. They feel more like a rivet?!
Is this to make it not serviceable or am I missing something? If anyone has a suggestion, please respond
Dave Schultz - 返信
Hi Dave,
Here,  I’ve Cuisinart DCC-1400 coffee maker but the 4 screws  on bottom is a torx with the pin in the center.
Check this , you need probably a torx driver with the hole in the center !
Jos
Jos -
Agree - any assistance in finding the replacement heating element would be most helpful. I have this coffee maker, and the metal clamp holding the heating element in place corroded through. Now the hotplate falls away from the bottom of the coffee maker. I’d like to replace the heating element and I assume it comes with the clamp in place - but cuisinart does not make any internal parts available to online parts retailers. Thanks!
David Miller - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 26
過去 30 日: 120
今までの合計 16,532
