メインコンテンツにスキップ
Creative Zen V Plus Headphone Jack Replacement
必要な工具と部品
  1. Creative Zen V Plus Headphone Jack Replacement, Prerequisite Only: 手順 1、 1の画像 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Headphone Jack Replacement: 手順 2、 1の画像 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Headphone Jack Replacement: 手順 3、 1の画像 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Headphone Jack Replacement: 手順 4、 2の画像 1 Creative Zen V Plus Headphone Jack Replacement: 手順 4、 2の画像 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Headphone Jack Replacement: 手順 5、 1の画像 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Headphone Jack Replacement: 手順 6、 3の画像 1 Creative Zen V Plus Headphone Jack Replacement: 手順 6、 3の画像 2 Creative Zen V Plus Headphone Jack Replacement: 手順 6、 3の画像 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Headphone Jack Replacement, Headphone Jack: 手順 7、 1の画像 1
    • Locate the circles of metal holding the headphone jack to the logic board. Using a soldering iron, de-solder these circles and remove the headphone jack.
終わりに
作成者
1人の作成者と共同作成されました。
Joshua Meines
メンバー登録日: 10/19/16
316 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S2G5
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 282
