はじめに
In this guide the charging port on the Creative Zen V Plus is replaced. It is recommended that you see the troubleshooting guide before attempting these repairs, as an easier solution may be found there.
必要な工具と部品
Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
Locate the charging port on the logic board. Around the base of the rectangular port you will find the circles of metal that were used to solder the port to the board. De-solder these circles and remove the port.
ある他の人がこのガイドを完成しました。
