メインコンテンツにスキップ
Creative Zen V Plus Charging Port Replacement
必要な工具と部品
  1. Creative Zen V Plus Charging Port Replacement, Prerequisite Only: 手順 1、 1の画像 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Charging Port Replacement: 手順 2、 1の画像 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Charging Port Replacement: 手順 3、 1の画像 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Charging Port Replacement: 手順 4、 2の画像 1 Creative Zen V Plus Charging Port Replacement: 手順 4、 2の画像 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Charging Port Replacement: 手順 5、 1の画像 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Charging Port Replacement: 手順 6、 3の画像 1 Creative Zen V Plus Charging Port Replacement: 手順 6、 3の画像 2 Creative Zen V Plus Charging Port Replacement: 手順 6、 3の画像 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Charging Port Replacement, Charging Port: 手順 7、 1の画像 1
    • Locate the charging port on the logic board. Around the base of the rectangular port you will find the circles of metal that were used to solder the port to the board. De-solder these circles and remove the port.
    • Learn how to solder and desolder components with this guide!
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Joshua Meines
メンバー登録日: 10/19/16
316 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S2G5
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 304
