メインコンテンツにスキップ
Corsair Void Pro RGB Lights Replacement
必要な工具と部品
  1. Corsair Void Pro RGB Lights Replacement, Earcup: 手順 1、 1の画像 1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Lights Replacement: 手順 2、 2の画像 1 Corsair Void Pro RGB Lights Replacement: 手順 2、 2の画像 2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Lights Replacement: 手順 3、 2の画像 1 Corsair Void Pro RGB Lights Replacement: 手順 3、 2の画像 2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Lights Replacement, Battery: 手順 4、 2の画像 1 Corsair Void Pro RGB Lights Replacement, Battery: 手順 4、 2の画像 2
    • Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
  5. Corsair Void Pro RGB Lights Replacement: 手順 5、 2の画像 1 Corsair Void Pro RGB Lights Replacement: 手順 5、 2の画像 2
    • Carefully unplug the wire that connects the battery pack to the headphones.
    • This should not take too much force.
  6. Corsair Void Pro RGB Lights Replacement: 手順 6、 1の画像 1
    • Remove the clear plastic covering and set aside.
  7. Corsair Void Pro RGB Lights Replacement, Lights: 手順 7、 2の画像 1 Corsair Void Pro RGB Lights Replacement, Lights: 手順 7、 2の画像 2
    • There is a small circuit board near the bottom of the muff.
    • Using a Phillips #0 screwdriver, unscrew the single screw holding the circuit board in place.
  8. Corsair Void Pro RGB Lights Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • Remove the circuit board from its plastic slot.
    • If this is the first time the lights have been removed from the headphones, you may need to wiggle the circuit board out of place or use plastic tweezers to loosen it from the manufacturer's adhesive.
  9. Corsair Void Pro RGB Lights Replacement: 手順 9、 1の画像 1
    • Desolder the three points where the wires connect to the circuit board. For detailed instructions on soldering, see this helpful guide.
    • Take note of where each of the wires goes to simplify the resoldering process.
    • Follow these steps again to replace the light on the other earcup.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Gianna Nobili
メンバー登録日: 04/15/19
836 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S9-G13, Maness Spring 2019 Cal Poly, Team S9-G13, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S9G13
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 29
今までの合計 1,353
