メインコンテンツにスキップ
Conair Infiniti Pro Model 259NP On/Off Button Replacement
必要な工具と部品
  1. Conair Infiniti Pro Model 259NP On/Off Button Replacement, Back Panel: 手順 1、 1の画像 1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 2、 2の画像 1 Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 2、 2の画像 2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 3、 3の画像 1 Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 3、 3の画像 2 Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 3、 3の画像 3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP On/Off Button Replacement, Fan Motor Assembly: 手順 4、 2の画像 1 Conair Infiniti Pro Model 259NP On/Off Button Replacement, Fan Motor Assembly: 手順 4、 2の画像 2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 5、 3の画像 1 Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 5、 3の画像 2 Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 5、 3の画像 3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP On/Off Button Replacement, On/Off Button: 手順 6、 1の画像 1
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
  7. Conair Infiniti Pro Model 259NP On/Off Button Replacement: 手順 7、 1の画像 1
    • Focus on the button directly next to the cylindrical capacitor.
    • Desolder the button at the circled locations.
    • New line.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Timothy Lo
メンバー登録日: 04/22/14
1,172 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S10G58
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 49
今までの合計 7,831
