はじめに
If your Coby Kyros MID9042 is not producing clear audio (including distortion, static, or anything that sounds unpleasant) this guide can help you replace the speaker with a new one. This guide will require soldering skills and preciseness for steps requiring wiring and dewiring. It is recommended to solder in a soldering work-station or something similar.
For soldering and desoldering instruction please review the soldering page to ensure wiring connections are well soldered.
必要な工具と部品
Remove the Anti-slip pads from all four corners of the back of the device.
Use Phillips #0 Precision screwdriver to remove the four screws from the back cover (screws are about 1/8'').
Desolder the red and black speaker wires from the circuit board. はんだ付けとはんだ除去の作業ガイド
Gently remove the speakers from the tablet.
When replacing the speaker, remember the red wire connects to positive and the black wire connects to negative.
