メインコンテンツにスキップ
Coby KYROS MID7125 Screen Replacement
必要な工具と部品
  1. Coby KYROS MID7125 Screen Replacement, Screen: 手順 1、 1の画像 1
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby KYROS MID7125 Screen Replacement: 手順 2、 3の画像 1 Coby KYROS MID7125 Screen Replacement: 手順 2、 3の画像 2 Coby KYROS MID7125 Screen Replacement: 手順 2、 3の画像 3
    • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger.
    • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
    • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
    • Desolder fifth ribbon cable with soldering station.
    • If soldering is new for you, then follow this useful guide on soldering and desoldering connections.
  3. Coby KYROS MID7125 Screen Replacement: 手順 3、 3の画像 1 Coby KYROS MID7125 Screen Replacement: 手順 3、 3の画像 2 Coby KYROS MID7125 Screen Replacement: 手順 3、 3の画像 3
    • Desolder 2 speaker wires
    • Desolder Battery
    • Desolder antenna wire
    • Disconnect all wires you desoldered
  4. Coby KYROS MID7125 Screen Replacement: 手順 4、 1の画像 1
    • Desolder the microphone wire
    • Disconnect the wires you just desoldered.
  5. Coby KYROS MID7125 Screen Replacement: 手順 5、 1の画像 1
    • Remove 4 screws that connect the motherboard to the device.
  6. Coby KYROS MID7125 Screen Replacement: 手順 6、 1の画像 1
    • Take off motherboard by lifting off right hand side and pulling sideways.
  7. Coby KYROS MID7125 Screen Replacement: 手順 7、 2の画像 1 Coby KYROS MID7125 Screen Replacement: 手順 7、 2の画像 2
    • Remove 4 screws on corners of the digitizer and lift off.
  8. Coby KYROS MID7125 Screen Replacement: 手順 8、 2の画像 1 Coby KYROS MID7125 Screen Replacement: 手順 8、 2の画像 2
    • Now that the digitizer is disconnected from the screen you can replace the screen.
    • Place the screen face down in front of you facing downward and apply pressure with your thumbs around the outside of the glass to remove the screen.
    • Next, replace with your new screen and follow steps in reverse order to reassemble.
終わりに
作成者
4人の作成者と共同で作成されました。
Nicole Connelly
メンバー登録日: 10/20/16
1 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S5G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 12
今までの合計 223
