メインコンテンツにスキップ
Coby DVD209 DVD Laser Reader Replacement
必要な工具と部品
  1. Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: 手順 1、 3の画像 1 Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: 手順 1、 3の画像 2 Coby DVD209 DVD Laser Reader Replacement, The bottom portion of the DVD player: 手順 1、 3の画像 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 DVD Laser Reader Replacement: 手順 2、 3の画像 1 Coby DVD209 DVD Laser Reader Replacement: 手順 2、 3の画像 2 Coby DVD209 DVD Laser Reader Replacement: 手順 2、 3の画像 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 DVD Laser Reader Replacement: 手順 3、 3の画像 1 Coby DVD209 DVD Laser Reader Replacement: 手順 3、 3の画像 2 Coby DVD209 DVD Laser Reader Replacement: 手順 3、 3の画像 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 DVD Laser Reader Replacement, DVD Laser Reader: 手順 4、 2の画像 1 Coby DVD209 DVD Laser Reader Replacement, DVD Laser Reader: 手順 4、 2の画像 2
    • Remove the two 6.35mm screws circled in black with a #1 Philips head screwdriver.
    • Remove one 4mm screw circled in red with a #1 Philips head screwdriver.
  5. Coby DVD209 DVD Laser Reader Replacement: 手順 5、 3の画像 1 Coby DVD209 DVD Laser Reader Replacement: 手順 5、 3の画像 2 Coby DVD209 DVD Laser Reader Replacement: 手順 5、 3の画像 3
    • There are three small 4.5mm springs that can be easily lost. Be careful when lifting up the railing assembly to make sure you don't lose them.
    • The location of the springs are circled.
    • Using two plastic tool removers, lift the two rails up at an angle. Keep the rods angled as shown.
    • The rail at the top of the picture is 82mm and the rail at the bottom of the picture is 65mm.
  6. Coby DVD209 DVD Laser Reader Replacement: 手順 6、 2の画像 1 Coby DVD209 DVD Laser Reader Replacement: 手順 6、 2の画像 2
    • Be careful not to lose the spring at the top of the laser.
    • Lift the laser assembly out of the fixture.
  7. Coby DVD209 DVD Laser Reader Replacement: 手順 7、 3の画像 1 Coby DVD209 DVD Laser Reader Replacement: 手順 7、 3の画像 2 Coby DVD209 DVD Laser Reader Replacement: 手順 7、 3の画像 3
    • Remove the rails from the disk reader.
    • Once the top rail is removed, the white gear will come off and under it will be one of the springs.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Yufay Chow
メンバー登録日: 01/23/12
92 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S10G36
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 815
