メインコンテンツにスキップ
Classen Over Seeder TS20HD 2012 Rake Belt Replacement
必要な工具と部品
  1. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Safety precautions: 手順 1、 2の画像 1 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Safety precautions: 手順 1、 2の画像 2
    • Before you begin, ensure that the machine is powered down and cool to the touch.
    • Disconnect the spark plug to prevent the engine from accidentally starting up during service:
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Classen Over Seeder TS20HD 2012 Rake Belt Replacement: 手順 2、 1の画像 1
    • To prevent the over seeder from rolling during service, place wheel chocks behind a rear wheel.
  3. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Tilt the over seeder: 手順 3、 2の画像 1 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Tilt the over seeder: 手順 3、 2の画像 2
    • Push down on the main handle to tilt the over seeder back on its rear wheels.
    • Place some weights on the handle, or tie the handle down, to prevent the machine from falling forward.
  4. Classen Over Seeder TS20HD 2012 Rake Belt Replacement: 手順 4、 1の画像 1
    • Place a wheel chock in front of a rear tire to keep the machine in place.
  5. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Unscrew the belt guard: 手順 5、 3の画像 1 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Unscrew the belt guard: 手順 5、 3の画像 2 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Unscrew the belt guard: 手順 5、 3の画像 3
    • Remove the four lock nuts securing the belt guard:
    • Two 1/2" lock nuts
    • Two 7/16" lock nuts
    • These lock nuts are recessed and require a socket extension to access.
    • Use box wrenches to hold the corresponding bolts in place as you loosen and remove the nuts.
  6. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Remove the belt guard: 手順 6、 3の画像 1 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Remove the belt guard: 手順 6、 3の画像 2 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Remove the belt guard: 手順 6、 3の画像 3
    • Remove the belt guard.
  7. Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Rake Belt: 手順 7、 2の画像 1 Classen Over Seeder TS20HD 2012 Rake Belt Replacement, Rake Belt: 手順 7、 2の画像 2
    • Use your fingers to pry the belt off the drive pulley.
    • If you are having trouble, make sure that the machine is not resting on the bail bar up by the handlebars, which tightens the idler pulley.
  8. Classen Over Seeder TS20HD 2012 Rake Belt Replacement: 手順 8、 3の画像 1 Classen Over Seeder TS20HD 2012 Rake Belt Replacement: 手順 8、 3の画像 2 Classen Over Seeder TS20HD 2012 Rake Belt Replacement: 手順 8、 3の画像 3
    • Squeeze the belt and unhook it from the engine pulley.
    • Remove the rake belt.
終わりに
Arthur Shi
メンバー登録日: 01/03/18
254,121 ポイント
529のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 48
今までの合計 687
