メインコンテンツにスキップ
Cineyo BT-03 Device Audio Jack Replacement
必要な工具と部品
  1. Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 1 Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 2 Cineyo BT-03 Device Audio Jack Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 3
    • Remove the top (button side) rubber cover using your hands.
  2. Cineyo BT-03 Device Audio Jack Replacement: 手順 2、 2の画像 1 Cineyo BT-03 Device Audio Jack Replacement: 手順 2、 2の画像 2
    • Flip over the device and remove the bottom rubber cover using your hands.
  3. Cineyo BT-03 Device Audio Jack Replacement: 手順 3、 3の画像 1 Cineyo BT-03 Device Audio Jack Replacement: 手順 3、 3の画像 2 Cineyo BT-03 Device Audio Jack Replacement: 手順 3、 3の画像 3
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
  4. Cineyo BT-03 Device Audio Jack Replacement: 手順 4、 3の画像 1 Cineyo BT-03 Device Audio Jack Replacement: 手順 4、 3の画像 2 Cineyo BT-03 Device Audio Jack Replacement: 手順 4、 3の画像 3
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
  5. Cineyo BT-03 Device Audio Jack Replacement: 手順 5、 1の画像 1
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
  6. Cineyo BT-03 Device Audio Jack Replacement: 手順 6、 1の画像 1
    • Gently pull apart the two sections of the device.
  7. Cineyo BT-03 Device Audio Jack Replacement, Audio Jack: 手順 7、 1の画像 1
    • Disconnect all wires from the top of the circuit board.
  8. Cineyo BT-03 Device Audio Jack Replacement: 手順 8、 1の画像 1
    • Using a small Philips head screwdriver, remove the two 5 mm screws from the main circuit board.
  9. Cineyo BT-03 Device Audio Jack Replacement: 手順 9、 1の画像 1
    • Use the soldering iron to melt the two contact points that attach the wires to the rear side of the circuit board.
    • This will require soldering off the wires connecting the bottom of the circuit board to the device. iFixit's Soldering Guide is available to aid in soldering.
  10. Cineyo BT-03 Device Audio Jack Replacement: 手順 10、 2の画像 1 Cineyo BT-03 Device Audio Jack Replacement: 手順 10、 2の画像 2
    • Remove the circuit board from the device.
  11. Cineyo BT-03 Device Audio Jack Replacement: 手順 11、 1の画像 1
    • Using a soldering iron, remove the audio jack from the circuit board.
    • There are four contact points attaching the audio jack.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Rene Klopf
メンバー登録日: 01/30/17
463 ポイント
4のガイドは作成済み
チーム
Baylor, Team 8-3, Whitney Spring 2017 Baylor, Team 8-3, Whitney Spring 2017人のメンバー
BU-WHITNEY-S17S8G3
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 132
