この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will walk you through the following steps:
- Removing the bottom of the kettle
- Locating and identifying the internal components
- Disconnecting the wiring from the internal components
- Removing the kettle power supply
- Removing the kettle control switch
Reassembly is as simple as reversing the steps!
必要な工具と部品
Remove the five 3/8" screws from the base of the kettle using a Phillips #1 screwdriver.
A: The power supply.
B: The two boil-dry protection switches, one on either side of the central black ring.
C: The power coupling. This fits into the baseplate when you place the kettle on it.
D: The thermostat. This is a little metal ring, half hidden by the switch cover.
E: The manual ON/OFF switch.
F: The indicator light.
G: The steam chamber. This heats the thermostat, which turns off the kettle automatically.
Remove the connectors (spaded lugs) from the circuit components as shown in the second image.
You should be able to remove each connector easily by hand. Pinch the lug between your fingers and pull in the direction of the attached wire.
If necessary, use needle-nose pliers to grasp the lug shank firmly. Gently pull the lug in the direction of the attached wire.
Gently bend the disconnected wires back and out of the work area.
FIRST IMAGE: Remove the power supply. Align the kettle as shown, with the handle to your right. Use the 7/32" nut driver to remove the 7/32" nut from the stud that is located clockwise from where the power supply was attached.
Use tweezers to remove the split-ring lock washer located under the nut.
SECOND IMAGE: Roll the kettle over so the handle is now on your left. Use the 7/32" nut driver to remove the 7/32" nut from the final stud, which is now located counter-clockwise from where the power supply was attached.
8 の人々がこのガイドを完成させました。
コメント 1 件
OK, now I can look from the bottom. But why the switch does not keep down when I press it down I can not see or repair.
Robert
