メインコンテンツにスキップ
Casio G’zOne Commando 4G LTE Sim Card Replacement
必要な工具と部品
  1. Casio G’zOne Commando 4G LTE Sim Card Replacement, Battery: 手順 1、 1の画像 1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Sim Card Replacement: 手順 2、 2の画像 1 Casio G’zOne Commando 4G LTE Sim Card Replacement: 手順 2、 2の画像 2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
  3. Casio G’zOne Commando 4G LTE Sim Card Replacement, Sim Card: 手順 3、 1の画像 1
    • After removing the battery you will find a port that is labeled SIM directly beneath where the battery was sitting.
  4. Casio G’zOne Commando 4G LTE Sim Card Replacement: 手順 4、 1の画像 1
    • Lift the tab that is located directly to the left of the card.
    • Slide the SD card out of its port to remove it from the cell phone.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Keith Hickey
メンバー登録日: 10/29/15
428 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-9, Miles Fall 2015 UMass Dartmouth, Team 1-9, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G9
3 メンバー
10のガイドは作成済み
2 件のコメント
My Casio C811 will not go to a browser, keeps saying no network connection. I am in an area that I have had connection with no problems before. The phone did some sort of reset on it own and now wont access any browser, google, Facebook ect. I have check the network setting and they appear OK. Any suggestions
bernmntsa - 返信
How do I unlock my Casio Commando C811 to use with non-verizon SIM…!?
Alrn Arun - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 4,584
