メインコンテンツにスキップ
Casio FX-991EX Battery Replacement
必要な工具と部品
  1. Casio FX-991EX Battery Replacement, Remove the battery cover: 手順 1、 2の画像 1 Casio FX-991EX Battery Replacement, Remove the battery cover: 手順 1、 2の画像 2
    • Remove the battery cover's screw using a Philips #0 screwdriver.
  2. Casio FX-991EX Battery Replacement, Remove the battery: 手順 2、 2の画像 1 Casio FX-991EX Battery Replacement, Remove the battery: 手順 2、 2の画像 2
    • Use a spudger to remove the battery using the gap to the right.
    • Don't use sharp objects that may cause harm or damage. The battery can be hard to pop out, but will do so. Dispose of a damaged battery via an e-waste collection site.
  3. Casio FX-991EX Battery Replacement, Replace the battery: 手順 3、 2の画像 1 Casio FX-991EX Battery Replacement, Replace the battery: 手順 3、 2の画像 2
    • The FX-991EX uses a 1.5V LR44 battery.
    • Slot the new battery into the compartment. Ensure that the positive side (with writing) faces up...
    • And the negative side faces the calculator's screen.
  4. Casio FX-991EX Battery Replacement, Screw the cover back on: 手順 4、 1の画像 1
    • Slot the battery cover back on and screw it down.
終わりに
If you need to reset the calculator after this, it's SHIFT+9 > 3 > =.
Otherwise, you're ready to crunch numbers again!
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
FarmYard Gaming
メンバー登録日: 08/27/20
1,850 ポイント
1ガイドが承認済み
4件のガイドコメント
Just discovered during a lecture that my battery has become a spicy pillow - if you're leaving this in storage be careful and monitor it, lest it explode and/or warp the case irreparably.
FarmYard Gaming - 返信
Which size of screws
李生山 -
I found nothing in the slot. What can i do?
UTL Shaion - 返信
Do you see any wires connecting the battery to the circuit board? I don’t see any on mine. Both of ours may be fake lmao
Ivan Liu -
コメントを追加
統計データ:
過去 24時間: 27
過去 7 日: 182
過去 30 日: 891
今までの合計 22,122
