メインコンテンツにスキップ
Casio Exilim EX Z55 Motherboard Replacement
必要な工具と部品
  1. Casio Exilim EX Z55 Motherboard Replacement, Front Case: 手順 1、 3の画像 1 Casio Exilim EX Z55 Motherboard Replacement, Front Case: 手順 1、 3の画像 2 Casio Exilim EX Z55 Motherboard Replacement, Front Case: 手順 1、 3の画像 3
    • Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
  2. Casio Exilim EX Z55 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
  3. Casio Exilim EX Z55 Motherboard Replacement: 手順 3、 1の画像 1
    • Separate the front case from the body of the camera.
  4. Casio Exilim EX Z55 Motherboard Replacement, Back Case: 手順 4、 1の画像 1
    • Separate the back case from the body of the camera.
  5. Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: 手順 5、 3の画像 1 Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: 手順 5、 3の画像 2 Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: 手順 5、 3の画像 3
    • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  6. Casio Exilim EX Z55 Motherboard Replacement: 手順 6、 1の画像 1
    • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
  7. Casio Exilim EX Z55 Motherboard Replacement: 手順 7、 1の画像 1
    • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  8. Casio Exilim EX Z55 Motherboard Replacement: 手順 8、 2の画像 1 Casio Exilim EX Z55 Motherboard Replacement: 手順 8、 2の画像 2
    • Continue to lift the LCD screen all the way up.
    • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  9. Casio Exilim EX Z55 Motherboard Replacement, Motherboard: 手順 9、 2の画像 1 Casio Exilim EX Z55 Motherboard Replacement, Motherboard: 手順 9、 2の画像 2
    • Remove the orange ribbon cable by grabbing the white tab with your fingers and pulling gently.
    • Potential for device damage: Be careful when handling the fragile parts of the motherboard; direct contact can damage it.
  10. Casio Exilim EX Z55 Motherboard Replacement: 手順 10、 1の画像 1
    • Remove the two 1.7 mm screws from the motherboard using a Phillips #00 screwdriver.
  11. Casio Exilim EX Z55 Motherboard Replacement: 手順 11、 1の画像 1
    • Using the iFixit plastic opening tool, pry the battery case clamps on the front of the camera so that the bottom will come loose.
  12. Casio Exilim EX Z55 Motherboard Replacement: 手順 12、 1の画像 1
    • Detach the inner orange ribbon cable that connects the motherboard to the lens by inserting the iFixit plastic opening tool under the tab and lifting up.
  13. Casio Exilim EX Z55 Motherboard Replacement: 手順 13、 1の画像 1
    • Separate and remove the motherboard from the lens.
    • It will be still be attached by wires and different orange ribbons.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Taylor
メンバー登録日: 04/18/12
46 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-45, Regan Spring 2012 Cal Poly, Team 9-45, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S9G45
7 メンバー
12のガイドは作成済み
コメント 1 件
I veganlover loved this guide! Although it wasn’t vegan enough
Alex Goodwin - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 972
