メインコンテンツにスキップ
Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: 手順 1、 3の画像 1 Canon Powershot ELPH 100 HS Battery Replacement, Battery: 手順 1、 3の画像 2 Canon Powershot ELPH 100 HS Battery Replacement, Battery: 手順 1、 3の画像 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: 手順 2、 2の画像 1 Canon Powershot ELPH 100 HS Battery Replacement: 手順 2、 2の画像 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Lillia
メンバー登録日: 03/17/15
267 ポイント
2のガイドは作成済み
チーム
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G10
2 メンバー
5のガイドは作成済み
3件のガイドコメント
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - 返信
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
What if the battery cover (gray tab) is broken?? I accidentally ripped it off.
Jade - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 49
今までの合計 2,015
