メインコンテンツにスキップ
Canon Powershot ELPH 100 HS Outer Case Replacement
必要な工具と部品
  1. Canon Powershot ELPH 100 HS Outer Case Replacement, Outer Case: 手順 1、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  2. Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 2、 1の画像 1
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  3. Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 3、 2の画像 1 Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 3、 2の画像 2
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  4. Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 4、 2の画像 1 Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 4、 2の画像 2
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  5. Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 5、 2の画像 1 Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 5、 2の画像 2
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  6. Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 6、 1の画像 1
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  7. Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 7、 3の画像 1 Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 7、 3の画像 2 Canon Powershot ELPH 100 HS Outer Case Replacement: 手順 7、 3の画像 3
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
終わりに
6 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jacob
メンバー登録日: 03/17/15
570 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G10
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 29
今までの合計 1,813
