この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will help Canon Powershot A70 owners replace the speakers, if the camera is not giving off sound.
必要な工具と部品
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove the wrist strap.
Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
Remove the two clearly visible screws from the control dial.
The dial should come off easily.
ある他の人がこのガイドを完成しました。
