メインコンテンツにスキップ
Canon Powershot A610 Speaker Replacement
必要な工具と部品
  1. Canon Powershot A610 Speaker Replacement, Speaker: 手順 1、 3の画像 1 Canon Powershot A610 Speaker Replacement, Speaker: 手順 1、 3の画像 2 Canon Powershot A610 Speaker Replacement, Speaker: 手順 1、 3の画像 3
    • Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
    • Remove the side paneling from the camera.
    • Remove the two remaining screws attached to the frame of the camera.
  2. Canon Powershot A610 Speaker Replacement: 手順 2、 1の画像 1
    • Remove the two screws on the bottom panel of the camera.
  3. Canon Powershot A610 Speaker Replacement: 手順 3、 1の画像 1
    • Open the battery cover.
    • Remove the four screws inside.
    • One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
    • Close the battery cover.
  4. Canon Powershot A610 Speaker Replacement: 手順 4、 2の画像 1 Canon Powershot A610 Speaker Replacement: 手順 4、 2の画像 2
    • Open the "DIGITAL AV OUT" door on the camera.
    • Remove the three screws.
    • Remove the door from the camera.
  5. Canon Powershot A610 Speaker Replacement: 手順 5、 1の画像 1
    • Gripping the sides of the top cover, gently pull apart the top cover from the camera.
    • The top cover does not completely detach.
  6. Canon Powershot A610 Speaker Replacement: 手順 6、 2の画像 1 Canon Powershot A610 Speaker Replacement: 手順 6、 2の画像 2
    • Gently pull apart the front cover from the camera.
    • This may require some force. Be careful not to break the plastic.
  7. Canon Powershot A610 Speaker Replacement: 手順 7、 2の画像 1 Canon Powershot A610 Speaker Replacement: 手順 7、 2の画像 2
    • Using an opening tool, push the black attachment away from the white connection piece to detach the connector ribbon.
  8. Canon Powershot A610 Speaker Replacement: 手順 8、 1の画像 1
    • Remove the 3 mm screw holding the metal frame.
  9. Canon Powershot A610 Speaker Replacement: 手順 9、 2の画像 1 Canon Powershot A610 Speaker Replacement: 手順 9、 2の画像 2
    • Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
    • Use a bit of force as the speaker is glued into the top casing.
    • There is a soft fabric speaker cover separating the speaker from the casing. Make sure not to remove it from its position in the housing.
  10. Canon Powershot A610 Speaker Replacement: 手順 10、 1の画像 1
    • Desolder the speaker at the two solder points and reattach the new speaker.
終わりに
作成者
8人の作成者と共同で作成されました。
Matthew Ramirez
メンバー登録日: 01/20/11
625 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 11-26, Maness Winter 2011 Cal Poly, Team 11-26, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G26
3 メンバー
9のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 12
今までの合計 2,963
