メインコンテンツにスキップ
Canon PowerShot SD1000 LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: 手順 1、 2の画像 1 Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 LCD Screen Replacement: 手順 3、 1の画像 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 LCD Screen Replacement: 手順 4、 1の画像 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 LCD Screen Replacement: 手順 5、 1の画像 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 LCD Screen Replacement, Front Case: 手順 6、 1の画像 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 LCD Screen Replacement: 手順 7、 1の画像 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 LCD Screen Replacement, LCD Screen: 手順 8、 1の画像 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 LCD Screen Replacement: 手順 9、 2の画像 1 Canon PowerShot SD1000 LCD Screen Replacement: 手順 9、 2の画像 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 LCD Screen Replacement: 手順 10、 1の画像 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 LCD Screen Replacement: 手順 11、 2の画像 1 Canon PowerShot SD1000 LCD Screen Replacement: 手順 11、 2の画像 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 LCD Screen Replacement: 手順 12、 3の画像 1 Canon PowerShot SD1000 LCD Screen Replacement: 手順 12、 3の画像 2 Canon PowerShot SD1000 LCD Screen Replacement: 手順 12、 3の画像 3
    この手順で使用する道具:
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
終わりに
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Phillip Phung
メンバー登録日: 01/19/12
651 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G18
4 メンバー
12のガイドは作成済み
1 Guide Comment
Very helpful. These units still sell for a lot more than the cost of the replacement LCD
George Francis - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 80
今までの合計 4,013
