この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This installation guide will help you remove your broken LCD and install in a new replacement.
必要な工具と部品
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
Remove the two 3.8mm screws near the strap bracket.
Remove the small panel covering the mounting bracket.
Remove the door covering the memory card.
Remove the plastic flap covering the motherboard.
Using your fingernail, open the black clip holding the ribbon cable.
Grab the ribbon cable and carefully pull it out of slot.
