Turn the camera with the bottom side facing up.
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Grasp the battery and fully pull it out of its slot.
When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
Start by laying the camera flat with the LCD screen facing up.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Position the camera with the bottom facing up.
Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
Repeat to remove the two 2.3mm screws.
Position the camera so that the rubber "AV Out Digital" tab is facing upward.
Slide the rubber tab to reveal the bottom screw.
Using the screwdriver, remove the two 3.7mm screws.
Turn the camera with the back side facing you.
Grip the edges of the back plate, and carefully slide it off.
If there is any resistance in movement, double check there are no screws left in the chassis.
Orient the camera as in the picture.
Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
Remove the two 3.8mm screws near the strap bracket.
Remove the small panel covering the mounting bracket.
Remove the door covering the memory card.
Turn the camera so that the bottom side is facing you.
Remove the 2.1mm screw using the Phillips #0 screwdriver
Grab the sides of the bottom panel and lift to expose the ribbon cable.
この手順で使用する道具:
購入する
Turn the camera so that the motherboard is facing you.
Using your fingernail, open the black clip holding the ribbon cable.
Gently pull out the ribbon cable in the direction of the cable using your fingers or tweezers.
Using a pair of tweezers, carefully pull the top ribbon cable out of the slot.
Grasp the sides of the LCD screen and lift off of the camera.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
