はじめに
Please follow these simple steps to replace your battery. Perform this procedure if you have a replacement battery or intend to charge your battery outside of the camera.
Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
Remove your finger and allow the flap to pop open.
Push the brown lever so that it pivots counterclockwise.
Grip and remove the battery.
ある他の人がこのガイドを完成しました。
1 Guide Comment
Hello Sr may be you can add something more ..I have this unit, really not using much ,After 6 month no charged I tried to used iven with new battery not start at all
thank you
