メインコンテンツにスキップ
Canon PowerShot A2200 LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot A2200 LCD Screen Replacement, Back Cover: 手順 1、 1の画像 1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 LCD Screen Replacement: 手順 3、 1の画像 1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 LCD Screen Replacement: 手順 4、 3の画像 1 Canon PowerShot A2200 LCD Screen Replacement: 手順 4、 3の画像 2 Canon PowerShot A2200 LCD Screen Replacement: 手順 4、 3の画像 3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 LCD Screen Replacement: 手順 5、 3の画像 1 Canon PowerShot A2200 LCD Screen Replacement: 手順 5、 3の画像 2 Canon PowerShot A2200 LCD Screen Replacement: 手順 5、 3の画像 3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
  6. Canon PowerShot A2200 LCD Screen Replacement, Button Assembly: 手順 6、 2の画像 1 Canon PowerShot A2200 LCD Screen Replacement, Button Assembly: 手順 6、 2の画像 2
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
  7. Canon PowerShot A2200 LCD Screen Replacement: 手順 7、 1の画像 1
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
  8. Canon PowerShot A2200 LCD Screen Replacement, LCD Screen: 手順 8、 1の画像 1
    • Lift up the electrical ribbon shown to access the next screw.
    • Remove the 3.9 mm screw with a Phillips #00 screwdriver.
  9. Canon PowerShot A2200 LCD Screen Replacement: 手順 9、 1の画像 1
  10. Canon PowerShot A2200 LCD Screen Replacement: 手順 10、 1の画像 1
    • Remove the two 3.9 mm screws shown with a Phillips #00 screwdriver.
  11. Canon PowerShot A2200 LCD Screen Replacement: 手順 11、 2の画像 1 Canon PowerShot A2200 LCD Screen Replacement: 手順 11、 2の画像 2
    • There is an electrical flap that holds the LCD ribbon down. Note the flap in is closed position.
    • Lift up the flap with a plastic opening tool.
  12. Canon PowerShot A2200 LCD Screen Replacement: 手順 12、 1の画像 1
    • Holding the outer frame of the LCD screen, gently lift the LCD screen for replacement.
  13. Canon PowerShot A2200 LCD Screen Replacement: 手順 13、 3の画像 1 Canon PowerShot A2200 LCD Screen Replacement: 手順 13、 3の画像 2 Canon PowerShot A2200 LCD Screen Replacement: 手順 13、 3の画像 3
    • This step is only for replacement. If you are not replacing the LCD screen, skip this step.
    • Locate ribbon flap, enclosed in red. (picture 1)
    • Using a plastic opening tool, lift up the ribbon flap to allow insertion of the LCD ribbon. (picture 2)
    • Place the LCD screen on the camera and align the ribbon underneath the open ribbon flap. Close the ribbon flap onto the ribbon. (picture 3)
終わりに
To reassemble your device, follow these instructions in reverse order, starting with the last guide step.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Benjamin Gee
メンバー登録日: 03/31/15
929 ポイント
5のガイドは作成済み
チーム
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S4G5
4 メンバー
11のガイドは作成済み
2 件のコメント
Step 11, “lift up the flap” did the trick - thanks !!
Mine got wet with seawater, I cleaned the electronics wih alcohol and it works again.
Chris W - 返信
My problem is after taking a photo and seeing the preview instead of going back to “live” display for the next photo the screen goes black but the camera settings still show.  Would changing the screen solve this problem?
Ken Short - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 40
今までの合計 1,314
